Allow External Visitor To Connect To Internet
I have an outside vendor coming into the office who needs to connect to our network via Cat5 and access the internet. His IP address scheme is 100% different to ours. What can I do without changing him to have one of our IP addresses to access internet?I have full access to our router. Any ideas?
Answered By 0 points N/A #97410
Dear Sharon,
About that situation you have, now you said that you have a full access on your router then that is good. Then now you go to the browser which you have then type in the Address bar the "ip address" of the router in this way sample "//192.168.2.1" then press enter. And it will ask for User name  and Password. Now once you're in the go to the setup then make sure it is "Dhcp" enabled so that it will provided automatic and IP Address, if "Static" you need to provide for the outside vendors PC and now on your setup of the routers maximum users if set sample to 5 users only then change it to 6 users. If dhcp is enable then just connect the Cat5 network cable to you're outside Vendor's PC.
Sincerely,
Jasonj
