Alternate For Windows 7 DVD Maker
From where can I download something similar to Windows 7 DVD maker? I want to make videos and edit them accordingly. Please help me out.
While you download Windows from online Microsoft Store, you cover two methods: Either you can download a compilation of packed in files, or you can download an ISO folder. An ISO folder combines all the Windows setting up files into a solitary uncompressed file. If you wish to download an ISO file so you can produce a bootable file from a DVD or USB drive, duplicate the Windows ISO file on top of your drive and then start the Windows USB/DVD Download device. Then just set up Windows on top of your computer in a straight line from your USB or DVD drive.
If you are looking for an alternative to Windows 7 DVD Maker, you probably want to try Windows DVD Maker. It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. It requires Intel Pentium II or equivalent AMD processor, 128 MB RAM, and 1 GB hard drive space.
It supports almost all major video formats like MP4, AVI, DivX, WMV, MPEG, and RM including 60 other video formats. It supports all DVD players, Media Centers, or Home Cinema Set. DVD types supported include DVD-5, DVD-9, mini DVD, and mini DVD DL. It allows you to create your own subtitles up to 32 subtitles as well as create DVD chapters.
The following subtitle formats are supported:
