I’ve been a Mac OS user for the last 15-years and now switching back to Windows because I just bought a Thinkpad X220. I think for Windows, there seems to be a version for everything that can equal the Mac OS applications except for Apple Mail. For me it’s still the best when it comes to the richness in graphics and still there is no email program in Windows that can compare with that, even the Thunderbird which is what I’m using now. I want something like Apple Mail or any email program that you could suggest that is as good as or better than Apple Mail?
Alternative for Apple Mail to be used in Window Based PC
Hello Taylor Paisley,
Thunderbird for windows is one of the best email clients, and in case you have not experienced any trouble while using it then I will advise that you continue using it.
But if you need to explore other mail client options, I will suggest that you try the windows live mail, it is on of the best email client for windows. The only setback it may have is that it may become slow in case hotmail is added to a POP3 email account on its own, but that is not something to keep you away from trying it.
You could also try outlook express, though for this one you will have to find the right version for the version of windows that you are using.
Hope this helps.
__
Regards
Mahesh Babu
