Hello folks! I mute all the players on dirt showdown mic mute function server but they complained they are complaining that I am still sending annoying sounds from my computer. I don’t know any alternative on these so that I could stopped this problem. Any alternative from anyone please? Thank you.
Alternative for dirt showdown mic mute function
Dear Heather
I have read your question and I understand that you are trying to mute your dirt showdown game microphone, the game still have sound, kindly check the following:
1- While you are in your game, open the steam community tab then open settings, and set your push to talk microphone to default.
2- Try to check your windows microphone and disable it if the game still make sounds
Go to start menu on your computer then control panel, sound, manage audio devices, recording, and microphone then click on properties then levels, you can adjust the level of your windows microphone.
3- Try to check the windows volume, click on speaker beside the clock then click on Mixer, here you can mute the speaker for applications you want.
