A. Meyers
15 points
Posted on - 10/13/2016
Logmein free software does not exist now but there are alternatives to it. These alternatives cost the same. They are used to access a document or support many desktops etc. Describe the alternatives of logmein remote access and desktop control software?
R Tiu
Alternative Of Logmein Remote Access And Desktop Control Software?
1) TEAMVIEWER
Download it from the company’s official website.
Run the downloaded extension on both of the computer that you wish to connect.
Provides a secure and easy remote access.
To run the programs, Ad Hoc users have to login from the controlling computer.
It installs as the server and also as the client.
This tool is practical and mature for remote-control needs.
It allows opening of several remote session, drag and drop files between the computers etc.
2) WINDOWS REMOTE DESKTOP
Fast and free.
Provides complete control over the computers.
They allow you to work from home.
Editing of registry can be done to provide control of multiple desktops by addition of ports.
3) VNC
Full form is virtual network computing.
Open source remote control.
Requires knowledge of IP addresses.
Used on a regular basis to control several computers.
You need to install it on all the PC’s.
You just need to enter the IP address to take control over it.
Cross platform.
4) WEBEX FREE
It is suitable for multiuser boardroom conferences as well as for small scale support.
Quite easy to use.
