Jean Moore
10 points
Posted on - 12/12/2012
What alternative options can I implement to repair the encrypted rar files destroyed by online virus while downloading and what steps do I need to follow in these options to facilitate full repair without loss of any single data?
Alternative means to repair the encrypted rar files apart from winrar software
Solution 1:
You can use any software that is designed to repair rar archive. For example:
Or
Solution 2:
This second solution takes more time but have more chance to successes. It consist to create par2 with QuickPar that you can repair after if the archive is damaged or corrupted.
Hi
RAR is a file format to store data in a compressed from.
Some time RAR files get corruptions due to following reasons.
Interruption while downloading
External threats (virus attacks)
Changing file extension
Memory error
CRC error
Write Error
I suggest you to download Repair RAR tool.
Hope this tool will helpful to you.
Thanks & Regards
MckinneyMa
Hello Jean Moore,
I am confirmed about your problems. I am describing step by step to repair the encrypted files.
Click to download the tool. http://www.repairrar.net/download/repairrar.exe
Run the program as an administrator.
Click > Next
Select the license agreement"I agree"
Select installation folder
Click next
After finalization of setup you have to Launch application
Complete registration with buying the product
Or select Offline registration
Select "Email machine code"
Send mail to [email protected]
You will get the activation code after 3 hours.
Activate the product
Select the corrupted file
Select location
Select "Repair "button
Good Bye
Thanking You
Shifflett Laurel
