bevis james
Posted on - 11/01/2011
Outlook 2007 is the most commonly used PIM that can be synched with a BlackBerry, so I installed it only to find out that I don’t like the different dialogs that contain items that I think would be useless for me. I don’t even like its UI. I’m thinking that there must be some alternatives aside from Outlook 2007. It would be great if this alternative could be directly synched with BlackBerry, but I’m okay with something that can be synched with Outlook. Can you help me?
Alternative program to sync directly with Blackberry
Microsoft Outlook is the most used email client to ever installed on a BlackBerry. This email client in most part allows you to send and receive email. This email client is separate application installed from a regular BlackBerry.
However, there are alternate 3rd party email client that you can install and enjoy the features they provide.
The main purpose why 3rd party email client used in BlackBerry is to access personal email messages, for business to easy track down by your company.
To be able to access email account that are important but you wish not to let them go, you can stored those email messages on your BlackBerry.
Here are the list of 3rd party or an alternate email client that you can use and install on a BlackBerry, see the following list below;
