An alternative to the Reflector app?
If the Reflector software does not work and it's unable to record the iPhone screen on the PC, is there an application that can be used as alternative? Will it only pair with a single computer at a time or can it be reflected on multiple PCs? Thanks for your help in advance.
Answered By 0 points N/A #199963
Unfortunately, these programs cannot mirror to more than one device. But you can mirror more devices to the screen.
For example, you can mirror two Apple devices to a single projector, or three apple devices to one single large TV screen.
There are two alternative programs to the Reflector software that you are currently using:
1. X-Mirage : this is an AirPlay server for Apple and Windows devices which allow you to stream your devices to the computer wirelessly. You can mirror multiple Apple devices to your Mac or Windows PC. You can also make demo video, design apps, record whatever you want, even games and apps. It features real-time monitoring, a password protection system, and audio streaming.
2. AirServer : this is a receiver for Mac and PC. It will allow you to receive feeds, just like an Apple TV, or stream contents by mirroring your display from other iOS devices or Macs. In a summary, you can beam your iPad or iPhone screen to a HDMI or VGA projector, or an HDTV, via a MAC or PC. It offers full screen display, a secure password connection, it's compatible with iTunes, and other picture enhancement settings.
