Alternative way to lower down the temperature of desktop
I want to add more ways to lower down the heat of my desktop computer. I want to know more Water Block EKWB. How does it work? What are the substances used to make the device keep its temperature level? How long does it take to use this before I need replacement? How much is the cost if I am going to buy it? What are the systems required and or where is it capable?
Answered By 5 points N/A #175427
The ekwb provides cooling solutions for all modern computers reducing the heat and hence temperature. The Full Cover Blocks are designed for all graphics card. All graphics card components are cooled by single cooling unit. The base is made up of SE CU electrolytic copper. The Full Board Water Blocks is latest version of EK family provides motherboard cooling solution. The cost slightly varies depend on your processor. It is compatible with all modern processors.
