anonymous
7060 points
Posted on - 07/24/2011
Hi, everyone. Recently I have noticed that the mouse of my PC has been damaged. I will buy it, but for the emergency need, how can I utilize my time using alternative ways? How can I complete my work without using a mouse?
Alternative way to use PC without mouse
It's so easy. After starting your PC completely, press left alt+left shift+num lock. You will find a box; Click ok. Now you can use your keyboard as mouse. Press 1,2,3,4,6,7,8,9 to move cursor.
Thank you.
shenna22
5 points
Hi good day,
In that case you must used keyboard, if you know the short cut keys of the keyboard but its better to use a mouse and keyboard, so that your work will never been delayed. You can be fast and handle it easily.
Thank you and have a nice day.
Shenna22
7thKnife
10 points
For emergency needs, you can use the mouse in the keyboard in alternative ways.
Go to Control Panel.
Click Accessibility Options.
Then Select Mouse.
Check the Box, Use Mouse Key.
Click Apply.
You can control the virtual mouse in the number pad: UP-8, DOWN-2, LEFT-4, RIGHT-6.
For emergency use, you can use the mouse in the keyboard in the alternative ways:
Go to control panel.
Click Accessibility options;
Then select mouse;
Check the box, use mouse key;
Click apply;
You can control the virtual mouse in the number pad: up- 8, down- 2, left- 4, right- 6.
