Jean Moore
10 points
Posted on - 11/28/2012
What could be the alternative problems in IDM apart from problem download proxy when I try to download from certain sites with the correct proxy settings that work on other PCs?
Alternatives problems in IDM apart from problem download proxy on proxy settings
Hello Jean Moore, If you parches the Internet Download Manager then there should not be any problem. If you do not buy it than a trial period problem should be there. If you try to register the Internet Download Manager with register key after trial period than you can see there a fake serial key that you inserted. Otherwise there should not have any problem. Thank you.
A licensed Internet download Manager can only be use with one system only. Multiple usage of a single license prohibits by the manufacturer or the distributer of the said software. If your software did not if you use software, preferable your software works without proxy. Some cause of this also the software cannot integrate downloads in your browser. Or, the proxies address it out within that boundary.
