I would like to inquire whether there are any other features which I can add to outlook to allow reminders get more alternatives. The snooze isn’t just adequate and its appearance cannot be changed or made impossible. Most people, including me would not prefer being queried though being reminded for events like pending meetings is just alright.
Alternatives reminders settings for outlook
Howdy Calvin,
A pleasant day to you. Please check out the links below and read it carefully to be able to solve your issue. You can learn a lot on that link. I have searched this to be able to help you out.
I hope that it will work:
http://products.secureserver.net/email/email_outlook.htm
http://www.optimizingpc.com/install/emailoutlook.html
You can also check the image below for you to be enlightened on what I am talking about. Please be noted that you need to follow the instructions so that you can solve your problem.
Good luck and have a great day!
Zorian
In outlook, you can add a appointment and you can add a reminder for that by following below steps.
Go to the Calendar > New Appointment > Give the subject > Give the Location > Give the Appointment day, Start time, End time > click Save and Close.
Reminder will automatically activated. When reminder is running, you can give Snooze time by clicking below snooze list and click Snooze button. You can add reminder and change Snooze time using this steps.
Also you can get some more details about sending an email as reminder by following these links.
Informational Site 1
Informational Site 2
