I am using MS Outlook 2010 in which I have received a few mails as BCC. It is showing my mail in BCC, but while printing it is not getting displayed. Is that the issue with my system or any settings in MS Outlook 2010, Please advice on whether it is possible to display the BCC in the Print, If so how to set always print BCC, Please guide me. Thanks
Always Print BCC in MS Outlook 2010
Hi John,
The following may solve your problem.
It’s possible but you can’t set it to automatically print the Bcc line every time you print.
The following are the steps to print the Bcc line and should be done every time you print:
1. Open your message.
2. Click on Office Button (upper left button)
3. Click EDITOR OPTION
4. Under POPULAR, check SHOW DEVELOPER TAB IN THE RIBBON.
5. Click OK
6. On Menu Bar, click DEVELOPER
7. Click DESIGN THIS FORM
8. Click and Delete SUBJECT and SUBJECT BOX (you will drag & drop this again)
9. On FIELD CHOOSER, click on drop down list, find ADDRESS FIELD
10. DRAG & DROP BCC below Cc…
11. RIGHT CLICK BCC BOX, then click PROPERTIES
12. A dialog box will appear
13. Click on VALIDATION, check INCLUDE THIS FIELD FOR PRINTING AND SAVE AS
14. Click OK
15. Resize the Message Box (so that SUBJECT and SUBJECT BOX will fit in)
16. On FIELD CHOOSER, click on drop down list, find FREQUESNTLY-USED FIELDS
17. DRAG & DROP SUBJECT below Bcc
18. Save & Close
19. Open again your message
20. Click Print Preview
21. Bcc should be displayed
22. Then Print
If you want to print the Bcc line automatically, you need to install MAPILab’s Print Tools add-in, visit this link for more information: https://www.mapilab.com/outlook/print_tools/
Hello, Jhon
Hope you are fine. Just follow the instructions
At first open the message.
Now Open the Forms editor
Tab Developer > Design This Form
Field Chooser will come directly. If not then click the Field Chooser button otherwise choose Form > Field Chooser
Click on "Frequently-used fields"
And select "Address fields"
Now drag & drop the BCC field under the "Cc:" field in the message
Right click on the address line of the Bcc field and click Properties
Now select the Validation tab and
Enable the option "Include this field for Printing and Save As"
OK to save.
Print it
Hope you will get your answer.
