Am having problems when trying to install hotfix 4 on windows 7.
I have a problem with using the hotfix 4. When I try to install it, I get the attached error image.Error:
Maybe this version of the patch utility tool does not support or did not find the appropriate files in your system that it will upgrade. If your Windows 7 is the newest version and you always update it using the Windows Automatic Update wizard then it is possible that this patch you are using may already not support your current Windows settings. If the patch’s reset to default option does not work, try restoring your computer to its previous state using Windows System Restore. I’m sure the patch utility tool automatically created a system restore point before patching the system. Use that restore point to restore your computer’s system.
After restoring your computer to its previous state, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton Utilities, Norton SystemWorks, or PC Tools Performance Toolkit.
