Hi, I want to connect my android phone into my computer but every time I connect the USB cable my phone does not show prompt to choose which USB mode I want to use. Am I missing a device driver for my android phone to get synchronize with my PC? Thanks a lot Techie people.
Am I missing android phone device driver to connect with my PC
Hello
You should get cd containing drivers for connecting your phone to computer. If you didn't get cd then find drivers according to your phone model on internet. You can also connect your phone with pc visa wifi. To do that connect your pc and phone to same wifi and download VeryAndroid SMS Backup utility and use it to sync pc with phone or you can just parse data. Here is download link: http://www.veryandroid.com/how-to-install-veryandroid-sms-backup.html
Regards.
Hi Mikey,
Anyway i think you really need a suggestion that could help you with your problem.But now all i can say and suggest for you,is your phone fell already?because android phones are sensitive,once they fell into the floor or somewhere else is they might be damaged and sometimes the other phones cannot use anymore.Try to search a website that has detecting phone damages and clear up your phone.thanks
