AM Radio App for my Android Phone
I've seen a lot of FM Radio applications but no AM Radio apps.
Where can I download this if there is one?
Yes, you are in luck, there is an AM/FM radio app available for Android. One of them is the TuneIn Radio.
It has both AM and FM frequency. It lets you listen to radio stations and podcasts from around the world.
You might want to check out this website Click Here
Hello Nicholas,
Don’t worry. There are lots of android apps by which you can get the facility of AM radio such as; TuneIn Radio, Bose® Internet Radio App, Pandora Radio etc. You can choose one of them to get the opportunity of AM radio.
But, I suggest you to use Tuneln and definitely you will like it.
You can download free Tuneln Radio app for your android phone from here: https://tunein-radio.en.softonic.com/android
Thank You. Enjoy your time.
Paul Jolie
