Amazing 3d weather gadget for windows 7
I just saw my friend's HTC , a 3D weather gadget that's really cool and very colorful. I need to inquire can i get the same 3D weather gadget for windows 7?
Hello Denise,
Sure you can get a 3D weather gadget for windows 7 too. It has got a full-fledged weather monitor and it will provide you with the comprehensive information concerning the current conditions as well as weather forecast, which include temperature, wind speed, direction, pressure and so on. You can download it here: http://www.freedownloadmanager.org/download/3d-weather-gadget-for-windows-7-1684807.html
Nicke
Hi Denise,
I am also a fan of HTC's weather widget on its phone and luckily for us this is written in C# + WPF in Visual Studio 2010 and someone already made a windows 7 version available for download. You just need to download the package and simply install it to your Windows 7 pc. Just make sure that your system has the following requirements:
Windows 8 or Windows 7 or XP or Vista and Microsoft .NET Framework 3.5 (SP1) or higher
If you'd like to have the HTC wallpaper as well you can have it downloaded.
Hope this helps you.
Waall Mike
Notifications
