Hi there,
I have an AMD system and I recently made a complete sweep of windows and start from scratch. I proceeded to install windows and it went fine, and later on when I started to install my drivers I noticed that the motherboard CD didn't come with the network drivers.
And the problem is I don't the model of the internal LAN card. So can any of you please give me the amd Athlon network driver download for Gigabyte GA-880GM-UD2h?
Thank you.
Amd athlon network driver download for system
Dear Floyd,
The LAN model for Gigabyte GA-880GM-UD2h Motherboard is Realtek 8111D chip (10/100/1000 Mbit).
You didn't mention what version of Windows your PC is running, So here you are a list of the driver for Realtk 8111D LAN which supports different Operating Systems.
– You can also use Realtek Ethernet Diagnostic Utility it is a useful tool for troubleshooting and finding problems with your LAN card. It supports Windows XP, Windows Vista and Windows 7. You can download it From Here or From Here.
