evan green
Posted on - 02/14/2014
I'm trying to install the updates on my graphics card from the manufacturer's website. It downloads just fine but the installation produce an error:
AMD High-Definition Graphics Driver
The contents of this file cannot be unpacked. The executable you are attempting to run has been corrupted. Please obtain another copy of the file, verify its integrity, and try again.
OK
I downloaded the update from AMD official site but why am I getting this kind of error? Can someone send me a direct link where I can download a working update? Thanks.
AMD Graphics Driver Content Cannot be Unpacked
If you downloaded the driver from the AMD official website then there should be no problem to think that it is the original file they are providing. Data corruption is possible when downloading files if your internet connection is slow and very unpredictable. I myself encounter data corruption at times when my internet connection is very slow.
The best way to deal with this is to download the file again from the AMD official website and you should do this during off-peak hours where the number of users connected to the network is very less. Another way is to visit AMD Graphics Drivers and Software. Here, you can select and specify the model of your graphics adapter and then download the latest version of the driver.
If you still have problems downloading the right version for your video card, you can use the AMD Driver Autodetect Tool. Just download and install it on your computer and let it find and install the correct version for you.
