malay_ball
10 points
Posted on - 06/10/2012
How can How we can compare AMDPhenom II X2 560 Black Editions Compared to Intel Core CPUs compare AMD Phenom II X2 560 Black Editions with Intel Core CPUs and which one are the shows the best performance in computing?
Difference between AMD Phenom II X2 560 and Intel Core CPUs
Hi
AMD Phenom II X2 560 Black Edition has this feature to add extra flexibility when overclocking. It is called the unlocked multiplier. When it comes to other features, I can tell small improvements. The AMD Phenom Black Edition can hit 3.3GHz only, a .1GHz difference from its predecessor Phenom II X2 555. The Black edition costs around $94.99.
On your post you didn’t mention what types of Intel Core you are referring t. We compare AMD Phenom II x2 560 to Intel Core I3 560. Both have almost the same 3.3GHz but will differ on the prices. Intel Core I3 would cost you around $138.
If you will buy the AMD Phenom II X2 560, to achieve 3.3GHz, you have to overclock. Intel on the other hand can hit 3.33GHz without overclocking.
Hope you will find this helpful.
Cheers
