AMD’s next-gen FirePro graphics cards
ADM has brought four kinds of Firepros in the market.
And they are Firepro W9000, W8000, W7000 & W5000.
Which one is the best to Play game and why?
Hi there buddy,
Upon researching answer for your question well to tell you frankly the answer is very easy because you are comparing AMD FirePro Technologies based on their Family Model. Well of course the Best is AMD FirePro because it has the most features, capabilities, speed and size.
Have a look in some of their specifications:
Amd Firepro W5000: It has the ability to process up to 1.65 billion triangles per sec, allowing a designer to easily interact and render the 3D models, while the competing solution is only able to process up to 0.41 billion triangles per sec.
Amd Firepro W7000: AMD FirePro W7000 gives up to 1.7 times more memory bandwidth than the competing solution, bringing the unmatched application responsiveness that professionals working with advanced visualization,
Amd Firepro W8000: Equipped with a large 4GB GDDR5 frame buffer, W8000 delivers up to 1.5 times memory bandwidth than the competing solution.
Amd Firepro W9000: Equipped with a massive 6GB GDDR5 frame buffer, W9000 delivers up to 1.8 times more memory bandwidth than competitive solutions 3.
Well of course in playing games the higher the better. Hope this chart that I provide helps you.
For more reading you can go to this link: Click Here.
Notifications
