AME Direct Path/File access error
Hi guys,
I am running XP SP2 and was trying to search for a specific file using a common dialog but when I click on the cancel button I get no name in the filename field and I get this error message;
AME Direct Path/File access error (75)
AME Direct
OK
Any help will much appreciated,
Answered By 5 points N/A #123700
Hi Sally,
You encounter the AME Direct error because it does not allow you to have the full access to read or write using the common dialog but this can be fixed. You need to go to this directory or location:
Local Disc C: Program Files AME Direct. Double click on AME Direct to open it.
Then, choose the option that will allow you to have the full access. If these steps will not fix the issue then you can try to create a new configuration by changing the INI file. Please read this link carefully and follow the steps mentioned:
Download Link.
Hope these helps!
