Amiga computer theme: Wrong installation?
amiga computer theme: I am using WinUAE and tried to install Amiga Theme for my PC. A friend recommended me to use it.  After installing, everything went black. The files were there but I didn't get the theme I want. What's wrong with it? What should I do to make it work?
Answered By 0 points N/A #142225
Hi
The theme you installed may not be compatible with WinUAE. Before you install Amiga you have to set up CPU, graphics, display settings etc. Before you installing a theme you should check if it’s compatible with your software and hardware specifications. Try the following solutions:
1. Check your hardware and software specification is compatible with the theme’s requirements.
2. Change the resolution of your Display.
3. You better remove the theme.
4. Try a reinstall of your OS.
