M Martha
Posted on - 07/12/2016
I need to buy a business telephone system but it is so overwhelming because of such a large amount of choices. Finally, after a bit of research, I have come down to two options, but still need to decide between them. Please help me settle the debate between Analog phones vs digital phones: Which are better?
Analog Phones VS Digital Phones: Which Are Better?
The telephone system you install should totally depend on your type of business, so before more research, you should make a clear outline on what you will be using the phone for.
Analog systems are cheaper and have most of the basic functions in place, also they have been in place for years and are very simple to learn and use. So, if you think your business will not be heavily dependent on the telephone system, go for this.
But, if you’re a big business venture and have a need for advanced features such as VoIP integration or alarm systems, you should invest in digital systems.
