Android app for SMS original invitations like that of InviteWiz
I need an Android app for sms original invitations like that of InviteWiz. I am already using InviteWiz in my Samsung Duos and I seem to be a great app for me. I was just searching for an app which is having more features than that of InviteWiz. If there is any such app, please suggest.
Answered By 60 points N/A #167135
Hi Nancy,
Hope you are doing well.
As you already mentioned you are using Invitewiz, that is indeed a great application. I would like to recommend some other application like GroupMe which is also available in android market and is compatible with your android phone also. This application will give you chances to send SMS to a group of people of your choice, you can treat it as your private twitter. 🙂
Find the Google play link of the said application:
