I am using phone 5. I want to use amiga photo edit in my mobile phone. I don,t know how I download or use in my phone if any body know about that please tell me how I use Amiga photo edit as a android Application?
Android application Amiga photo edit
Amiga Photo Edit is not very much offered in the Internet. Explore in the Google. If you are fortunate enough, then you may find the software. My recommendation is using Instagram instead of Amiga. It is easy to find and download it rather than Amiga. Other apps are also suitable and available for photo editing.
I would like to tell you something that saves your time
1- You cannot install or run an android application on iPhone as android application works only on mobiles with android operating system.
2- Android operating system is completely different from IOS so it is very difficult to transfer an application to work on another operating system.
3- If you converted an application and succeeded it may be an illegal matter.
