ANDROID APPLICATION FOR MOBILE PHONES
Losing your Android phone can be a big problem because you do not only lose your phone, but you also lose all your important files, contacts and all the information that it carries especially if you do not sync your phone with your computer. There are a number of free Android apps that are available in Android Market which helps you find or track your lost Android phone.
These apps use your phone’s GPS or WiFi connection to locate the phone using the Internet and a web browser. If your phone is lost and it is switched off then there is nothing running on it to help you find it.
Your only chance of locating it is when someone turns it back on.
Hi friend,
Thank you for asking your question here and I am willing to help you. There are some application available in android market that can track phones when it is lost.
But the sad thing is it cannot track your phone when it is turned off. Sad to say it is not possible that your phone will be found unless when it will be switched on.
The best you can do is report it to the right institution that can help you so that they can investigate the problem.
I am very sorry I don't know any application software that can track phone when it is turned off.
