Android Apps on Windows Mobile OS
There are many applications that we want that is not compatible with windows mobile OS they should upgrade there system so we can enjoy it more. But there are some android applications that run in windows mobile OS.
You can browse some of this on this ( https://www.howtogeek.com/howto/20703/run-android-on-your-windows-mobile-phone/ ) ( http://www.techradar.com/news/mobile-computing/tablets/how-to-run-android-apps-on-windows-1042650 ). This are only few, maybe in the long run they can develop more application for windows OS or windows can provide something for there clients.
I found different ways of using Android applications on a Windows Mobile Smartphone. The first one is by doing emulation using a software called Haret. This emulation software enables Windows phones to run Android operating system side by side with Windows Mobile 6.x. To do the emulation, you need to boot to Windows Mobile first before you can run Android using Haret.
The other method is by making the Smartphone to do dual boot using a new software called Gen.Y DualBOOT. This software enables the Smartphone to actually do a dual boot between Windows Mobile and Android OS on the very same handset.
The Gen.Y DualBOOT software supports WVGA, VGA, and QVGA devices and can be used to boot Android from both the internal and external storage cards [MicroSD]. To see the instructions on how to download and install the software, you may visit Dual Boot Windows Mobile and Android.
You can also watch the video below on how to do the dual boot on Windows Mobile and Android.
[video:http://youtu.be/Nvj4ObHmxCI]
