Android button software, why this is here?
Hi guys
Any of can say what is the reason to introduce Android button software? I am dying because of it. I just can't fix this problem of my cell. Is there is any remedy?
Hi guys
Hi Corey Joel,
Android button software is for make your smartphone more user friendly. some times your handset keys are broken by pressing many times. If you install this software , no need of button in your smartphone.these are the virtual keys on your phone's Display.
If you want to download this software, visit mentioned site:
I hope it will be helpful. Thank you!
Many Android users are having a hard time with the new software button. We are all used to soft button that’s why having a software button on our Android phone makes it like an alien to us.
Software button was introduced by Google in Android 4.0. Anyway, I suggest that you look on the good side to appreciate this new product. With the software button, you can have a bigger viewing angle when you’re watching movies and playing your favorite games. Not to mention that it is more pleasing than the regular buttons.
