Android Document viewer and macros
HI there,
I have a presentation in spreadsheets involving macros which I wish to use an Android Tablet to project them via wireless projector, how do I enable Macros on the android's document viewer? What else can I use to make the presentation run okay?
Answered By 10 points N/A #199701
Droidsheet is a spreadsheet application which has been written for Android Devices. It has got all standard spreadsheet management features including Macro operations.
Another Android application is e-Droid-Cell Pro Spreadsheet. They say it 100% Excel compatible and also includes a “Macro” mechanism allowing to script the application. Also, it allows majority of the functions as supported by a Macro language (JavaScript Macros).
You may also search the Android online market for any other full spreadsheet supported (including Macro support) for your presentation.
