Jeff Scott
10 points
Posted on - 12/10/2011
My Android gadget rebooted automatically and I received the attached ‘Force Close’ message. You can guess how annoying it could be. All on a sudden it my android is malfunctioning. I would appreciate your comments about this thread. The attached ‘Force Close’ message may give you some idea which application is responsible for the unexpected reboot. The highlighted portion of the attachment is provided as an example of Force Close error message. Your prompt feedback would be a real help in the circumstances.Â
Sorry
Mail has stopped unexpectedly.
Please tell HTC about this problem.
To help HTC improve Mail, select
"Tell HTC" to send an error to HTC.
Android gadget auto reboot issue
From the error message, it seems that the error is being caused by some problems that are prevailing the mail settings. Did you by any change the email configuration settings on your phone, because if you did then that is the possible cause of the problem? I will suggest that you try the following:
Go to the mail server that you using on your phone, or even if it is the normal phone messaging service and check if you might have changed the settings and reconfigure them.
You might also consider restoring the phone settings to factory settings, though that will mean that other settings including the message settings will be affected.
Also try restarting the phone and see if that may help in some way.
Regards
Thompson Locker
