Android Java browser for free
I need a mobile browser that will support both Android as well as Java, Is it possible to have an Android Java browser for free. If so please do the needful for suggesting the best Android Java browser that is freely available in internet. It will be more helpful to have a download link to the mentioned browser.
Answered By 0 points N/A #193370
Hi Ria,
Android and Java are two totally different mobile operating systems. If are thinking of getting a browser which will work for both Android and Java, you cannot expect much. Android Applications bear the extension of *.APK, while Java Applications bear the extension of *.JAR.
So, there is no possible way one program could work in the other Operating System. However, I can give you resources to browsers of Opera. They are available in both Android an Java. You can easily download the Opera Web Browser for your Android Device from Google Play
For downloading Opera for Java Environment in your mobile phone, you can target your native browser of your mobile to the Opera Mini Download Page.
Regards
Answered By 590495 points N/A #311369
If you are using an Android phone, I don’t think you still need to install a new web browser because your phone already includes a pre-installed Google Chrome web browser. You simply need to update it if your phone is new because the apps on your phone are all stock applications and most of them are already outdated like the Google Play store and YouTube apps, for example.
The Google Chrome web browser on your phone is capable of running Java apps and flash contents. Actually, all web browsers that you can install on your phone support Java. So, there’s really no need to find a Java web browser. To update Google Chrome on your Android phone, update Google Play store first.
