Android Media Importer Software from USB Flash Drive
I need a Media Importer which will allows me to import and stream music, video, photos and documents from a USB flash drive. Which Media Importer is best for my brand new android?
Hi Ingridgonzalou i searched a solution that may help your problem.
I recommend Nexus Media Importer it really allows you to import those video, photos, stream music and even your documents from your USB.
You just need these two things:
Hardware
OTG cables
It connects from your charging port of your android to the USB. Maybe some other cables will do but I recommend using this one. You can get it from
https://www.amazon.com/T-Flash-Adapter-Samsung-GT-i9100-GT-N7000/dp/B005FUNYSA
Flash Reader
Hope it will help you.
