Android or Windows mobile for Samsung and HTC mobile phones
Hi there ,
There is absolutely no confusion in that . Let me say this . ANDROID IS THE BEST.
Windows mobile wont even is one percentage better than Android. I have used both . I had a use Nokia Lumia and a new other series mobiles and i recently purchase Samsung Galaxy Y and also Galaxy Note.
Android is simply awesome yaar . Go for it. And buy HTC or Samsung phones only . I didn't find any good in other companies.
Samsung is the best let me say . Its value for money mobile. One problem with HTC is the Over price and low specs but the HTC sense UI is the best UI i have ever seen. Samsung is little low in UI.
Go for Galaxy S2 or note.
Good luck.
It would also be best if you choose Android over Windows Mobile. The latter is recommended for multi-core processor Smartphones so if you are not using a slightly fast phone, Windows Mobile might decrease the device’s performance. Windows Mobile 8 is the new Smartphone operating system from Microsoft which is what’s running Windows Phone 8. Most of its codes are really based on Windows 8. Windows Mobile 8 already comes with Microsoft Internet Explorer 10 and is already complete with malware blocking and supports HTML5.
The result is an integrated ecosystem wherein developers can easily create apps and drivers that can be used on phones, tablets, and desktops. This version now of Windows Mobile is already capable of handling multi-core processors unlike in Windows Phone 7 where it doesn’t support even a dual-core processor. It has a new Start screen. It still has the metro tiles but they are now customizable. It now supports new screen resolutions:
It has a lightning fast browser and that is Microsoft Internet Explorer 10. You can expect a better apps experience together with NFC [Near Field Communication], Wallet Hub, Skype, and VoIP. If you want to see the complete details on Windows Mobile 8, you may visit Features of Windows Mobile 8.
Notifications
