Android OS or Windows 7 OS?
Need Suggestion. Which one is better? Android OS or Windows 7 OS?
I want to buy pick out one of them. (Android tablet with 1.4 GHz Speed, Win7 tablet with 1,66 GHz).
Thanks!
Thanks!
Hey Jreyes!
Both of the phones are awesome and pretty cool. But both of the phones have some Pros and Cons.
Let have a look at Windows 7 OS:
CONS:
PROS:
Now let us move towards the Android OS:
PROS:
CONS:
Now the question is, which one is best for you. If we analyze the PROS and CONS of both Mobiles, we come to know that the Android OS is better than Windows OS. I will recommend you Android OS.
Thank you Jreyes for that interesting question. I am using right now windows 7 and it works well for me. I find it great and a high performance. Windows is better than Android OS because I am used to using it.Â
It is very user friendly and I find it comfortable of using it. But it is just depends on the preference of the person his taste is using the Android OS. For practicality purposes Windows 7 is preferable.
Clarence
