My android pc screen has gone black. I do not know what happened. Last time I used it, it was working fine but now it is not working anymore. Each time I restart it the result is the same. Please someone help me solving this problem. I really need to know if this problem cannot be solved manually before taking it to the experts
Leo kingston
Android pc -help required as quick as possible
Well Leo kingston, it seems to be a hardware issue. Which android tablet are you using? The problem could most probably be in the digitizer of your screen. Digitizer is a small sheet on the back of the LCD and if there is some issue with the digitizar or it gets misaligned slighlty, then the screen gets blank. You need to take your system to a hardware expert who will open it up and see the actual fault in the systsm. If it really is the digitizer, then it is good as it is not very costly. However, if the issue is in the motherboard, then it will be a lot of money to spend for you. In that case, you can analyze if you want to get it repaired or sell it as it is for hardware components. I hope though that it is only the digitizer and your problem will be solved. Good luck !
