Android phone stuck in android logo
How can I fixed my android phone ?
I just reset my phone and after that it does not continue and stuck on android logo.
I just install some application, and that application require a restart.
After that I'm stuck on android logo.
Answered By 590495 points N/A #106610
If your phone got stuck on the android logo after rebooting, try turning it OFF then remove the battery at the back for a couple of minutes. Then after a while, connect the battery again then start the phone. This way, it will drain the phone from all the current supplied by the battery that might be affecting the phone’s booting. If this still does not work, I think you may need to restore your phone to its factory settings. Here’s how you can do it.
  1. On your home screen, click on Menu.
  2. Click Settings.
  3. Select SD & Phone Storage.
  4. Select Factory data reset which is located at the bottom of the screen.
  5. Select Reset Phone.
This procedure of restoring the phone back to its factory settings will erase your Google account, all your installed applications, custom settings, and other downloaded applications from your device but excluding the SD card. You need to install again all of the applications you have previously installed after the reset.
