Android Tablet hangs after displaying logo
I have an Android Tablet model M806S and it was working fine until a few days ago where it can’t start properly. When I turn it on it tries to start but after the Logo is displayed, it hangs completely until I press the reset button then it tries to start again and the process repeats again and again. Please help.
Best Answer by Dawn Johnson
Answered By 0 points N/A #189956
Use this trick for any android tablets. First press and hold power button and volume up button together. This will take you to the system recovery screen. Then it will ask you to press only power button for 10 seconds and that’s all. It will try to recover your system. In this case you may lose your stuffs that you downloaded.
Hope this will work.
Answered By 0 points N/A #189955
Hello there !!
You have not mentioned what brand Tablet you are using. Ok, this is not an issue, Let me tell you the actual reason for the occurrence of the error with your android device. Since your device hangs after displaying the Logo this is because your device is not able to load the boot loader of the Android operating system which is installed in it. And this is due to the corruption in the boot loader file of your android operating system. So restoring the device won't be worth for you.
So what you need to do is to install the operating system yourself by routing the device else take the device to the service center.
