Android vs iPhone tech query
What is the difference between jail breaking an android phone and an iPhone 4S?
Why one should prefer an iPhone over an android phone?
Hello there again buddy,
In my opinion both iPhone and Android have their advantages and disadvantages. And also depends to the user what really features and design they want that’s why choosing IPhone Vs. Android will still up to the persons personal choice.
But Based on the people’s choice and some survey’s these is their answer.
Iphone Vs. Android
IPHONE |
ANDROID |
Hardware: Choice Vs. Polish |
Tie |
Tie |
OS Compatibility: Awaiting Game |
Winner |
Apsps Selection vs. Control |
winner |
Gaming: A growing Giant |
Winner |
GPSS Navigation: Free Wins |
winner |
Flash: A Difficult choice |
Winner |
Battery Life: Consistent Improvement |
Winner |
Screen Size: How big is too big? |
winner |
Networking |
winner |
Carriers: 4 vs 3 |
winner |
But well in the end its still up to the user. Hope this helps have a nice day.
Jailbreaking is to iPhone as "rooting" is to Android.
Once you do so, "you break the device’s metaphorical walls in order to gain better access to the device and it’s operating system to allow better end user control of it’s functions.
The major differences in jailbreaking/rooting:
1. First Party Support (Apple doesn't want you to jailbreak your device. If it is, then don't bring it to an Apple Store. Google (for Android) on the other hand doesn't care if your device is rooted or not.
2. Recoverability (If your iPhone is jailbroken, its easy to un-jailbreak. Un-rooting an Android phone is not as simple. If you don't do the process perfectly, you might end up with an unresponsive phone).
Please refer to this link for a better comparison between an IPhone and Android device and see reasons why choose an iPhone.
You are asking too different questions, but I will provide an answer to both of them.
Here are some key differences between jailbreaking an Android OS and an iOS
Regarding your second question:
I hope this helps.
We call jailbreaking on Android as "Rooting" Android phones. Android is an open source OS and can allow the users to install more than just the 3rd party applications. Side loading or installing 3rd party apps on your out of the box android, allows the user to install themes and install applications directly from your SD card or the internal memory of the Android devices. Rooting gives the user an access to more or less the entire OS.
Users can completely remove the OS and replace it with user made OS with tweaks and some improvements or ROMS. You can even setup your desired settings such as the speed of the processor. With custom kernel, you can over clock or under clock the speed of your processor on your Android device. Users can also access the flash memory chip.
Jailbreaking on IOS devices allows the user to do things on their iPhones that they can't do when it is not jailbroke. Jailbreaking is a method of removing restrictions and limitations on your iPhone such as downloading apps that are not in the App store, use themes and extensions that is not supported by Apple.
This does not affect the standard functions of your iPhone, you can still access iTunes and App Store.
Hi D_shekhar
Check out this Techyv post to get more information about the difference between jail breaking an android phone and an iPhone 4S.
