Corin Ronie
10 points
Posted on - 03/16/2013
I am in need of an Android WIFI Power Saver app that will automatically off Wifi when there is no network and thereby saving the power consumption. Will I be able to get this app for free through Google Playstore, Please do the needful for providing me a downloadable link towards this app.
Hello Corin!
I think this app will work for you.
It caters your needs. This will automatically turn off or disable your WLAN or WiFi on your device, thereby saving battery consumption. If you want to check if there are available networks on your location, you can always enable the WiFi on the device, but if it does not detect any connection, the WIFI Power Saver will automatically disable the wlan.
