Angry birds application configuration is incorrect
Hi friends,
I was playing angry birds on my system with windows XP installed and suddenly I got the following error message on my screen:
The error says:
The application has failed to start because the application configuration is incorrect.
Reinstalling the application may fix the problem.
Does anyone know how to fix it up? Please do let me know if you have a solution.
Thanking you loads
Regards
emma
