Hi guys,
I have recently started playing Angry Birds and I also watched a video on how to create the level. I copy pasted the codes into wordpad and by doing so I replaced the Level 1.Lua file. Then I started Angry Birds level 1 but the following error appeared on my screen. The screenshot of the error is as follows:
He error says:
Error
?:0: attempt to index failed? ( A nil value) (call stack not available).
Can anyone please explain how you solve the issue? I'll be really grateful.
Waiting for your reply.
Jones
Angry birds attempt to index failed error
Hello Jones,
Hope you are in troubleshooting with your most favorite angry bird game. Don't worry here I suggest you to get rid of from this troubleshooting.
Primarily you should download updated demo version of Angry bird and execute the installation and select for repairing.
If the problem persists, remove .lua in settings or replace it and then the game will be restarted.
You will find the file in userapp data Rovio angry birds at documents and settings option of C: folder.
Show the hidden files and after finding out .lua file you can successfully get rid of the problem after removing it.
Best of luck.
Hallo Jones,
You will have to cross check the code that you pasted and ensure that it is correct, for you may be getting the error due to using incorrect code. If the issue still persists, you might need to uninstall the Angry Birds application for it may be having bugs, and then perform its clean installation.
Nicke
