Angry Birds jar file for Java mobile
I am using Java Mobile for which I need Angry Birds jar file. Please do the needful for providing me the free download link. Thanks
You can download the Angry Birds Jar file from the link below:
https://java.mob.org/game/angry_birds_rio.html
And then select your handset model so you can get the correct game resolution that will fit on your device.
Hello David!
In the midst of Android Development and environment, I am overwhelmed by the fact that you are still considering the use Java in mobile gadgets.Â
Here are the links where you can download the Angry Bird jar file:
Hope it can help.
Hello dear
Angry birds are one of the famous game iOS and Android mobile. you want to download jar. file on your java mobile. There is the simple way to download jar file on your java mobile.Please follow The links below….
Download Angry Birds 240×320 JAR file
Download Angry Birds For Touch Screen Phones
I hope That's will be HelpfulÂ
ThanksÂ
