Angry birds for pc 32 bit free download crashes
I just installed the Angry Birds for PC 32 bit free download. When I launch the program, the gameplay suddenly becomes slow then crashes. I have a desktop with Intel Core i5, 4 GB RAM, 1 GB Geforce video card and Windows Vista OS 64 bit. Could this be a compatibility issue?
Answered By 10 points N/A #139674
Dear David,
The Minimum System Requirements are:
OS Windows XP SP2.
RAM 512 MB.
CPU 1 GHz.
Graphic OpenGL 1.3 compatible.
Internet Connection required for activation.
So your PC is meeting the minimum requirements.
You should try getting the latest Graphic driver update. If your video card driver is out of date, it could cause the crashing problems.
Here you can get the latest driver for your GeForce Graphic Card : Nvidia Driver Downloads.
NVIDIA Driver Downloads
Finally make sure to follow the latest updates of the game you have, It usually has bug fixes. Since you didn't determine what edition of Angry Birds you have, I can't tell you exactly what update you need.
But in the following link you will find a complete list of all the updates of Angry Birds editions running on all the platforms.
Angry Birds Updates List
