Hello!
I am a voice-over artist and I would like to give more extensibility on my talents. What is this Voice Changer Software Diamond 8.1? Can I download it from Google Store? What are the system requirements for me to run this in my phone? What are the best features that I can use to alter my voice recordings? Can I download this also to my computer? What are the file formats supported and to export it? Can I sync this software with Sony Sound Forge?
Animating your voice using Android Application
Hi Pamela!
The Voice Changer Software Diamond 8.1 is a software that you can use to alter or change your voice. You mimic, make a voice-over experiments and practical jokes are the most common usage of this software. You can download it to any online store, the best thing about this it is for free. This software is only intended for desktop and laptop use only.
Here are the system requirements to use this software.
1. Windows PC this is not available in Apple or Mac.
2. The processor must be 1GHz or higher.
3. The RAM memory must be 256MB or higher.
4. You need to have available disk space of 100 MB.
5. Your sound card must be Full-Duplex support
6. Your audio device required is a normal headset for voice conversation or microphone and speakers or an USB headset.
There are several features included in this software that you might find very useful for your intents.
1. Voice-over and voice dubbing. Mimic any voice that you can sound like, mimic animal sounds
2. You can use this to any voice-chat applications and also VOIP and instant messaging applications.
3. Works with in-game voice chat systems.Â
