Is animations are possible using ashampoo x software
Hello expert, I am using ashampoo x  mailer in editing and  cropping images.  When I am cropping the images/photos using shortcuts. The changes are not saved, so that I am performing changes repeatedly. Please provide me some shortcut keys that can work with ashampoo x mailer.  Is it is possible to  mail animated images/photos using ashampoo x mailer. Please provide me a full version of ashampoo x mailer software?
Best Answer by Harrington Curtsinger
Answered By 0 points N/A #141817
You can find/ download the Ashampoo products from the official Ashampoo site.
Ashampoo has a wide range of products available. For shortcut keys there is not such tutorial or web reference available, you will have to learn on trial and error basis by you self. I would suggest to go through the product support document and the manual pages.
Ashampoo also provides Free Online Scan for your computer.
HTH!
Answered By 0 points N/A #141818
"                     All you can do is to Download Soft32Download.
Ashampoo Photo Mailer' 1.0.2 is Trial Audio Encoders/Decoders software   design by Ashampoo GmbH and Co KG. It runs on following operating    system: Windows XP / Vista / Vista64 / 7 / 7 x64 / 8 32-bit / 8 64-bit and has as system requirements:
•        2,0 GHz (or higher) CPU.
•   Graphic adapter min.resolution 1024 x 768 with 256 MB memory.
•        Microsoft .Net Framework 4.0
•        512 MB RAM
This requirements helps you a lot .
