sirnirvana
Posted on - 06/01/2012
Anime Studio Pro 7.0 is not opening after I have successfully installed in my laptop (window 7)
Anime studio 7.0 is working very perfectly in desktop computers but I am having trouble to make it work on my pc laptop.
This really makes my animation works delay as I have to only with desktops.
I really want to make it work on my window 7 laptop so that I can work wherever I go.
Please help to fix this problem.
Window Studio Pro 7.0
Window Studio Pro 7.0 has stopped working
Windows can check online for a solution to the problem.
Check online for a solution and close the program
Close the program
View problem details
Anime Studio Pro 7.0 is getting trouble to open
I’m not sure why this program is showing signs of poor performance when you are using it on your laptop with Windows 7 installed on it. And besides, your operating system is pretty much supported by this application. To have a clearer view of the application, let’s review its system specifications. Anime Studio Pro 7 works on Windows XP, Windows Vista, and Windows 7. It doesn’t mention any information about the required edition, the Service Pack, or whether to use the 32-bit or the 64-bit version. That’s why, there’s really no problem installing this program on your computer.
This program requires at least Intel Pentium 500 MHz or any faster processor and needs around 600 MB of available hard drive space. You can even run this program with at least 256 MB RAM installed. You should also install Adobe Flash Player 9 or later versions to make this program work. If you haven’t installed Adobe Flash Player yet on your computer, download the latest version of Adobe Flash Player here.
To learn more about Anime Studio Pro 7, please visit Multiply — Anime Studio Pro 7.
