Another Language In Windows 7 Enterprise
I need help in installing Chinese language in my Windows 7 Enterprise Edition.
I am running 64 bit.
Thanks in advance.
Jake
Thanks in advance.
Jake
Click Start, Click on All Programs. Browse for Windows Update and Click on it. Click Check for Updates in the left side to download current available updates to your system. Now, you will see that you have a number of optional updates available click on that. In the category of Windows 7 language pack. Select which language you want to install and click OK and then Click install updates to start the download and installation process
After downloading, It will be installed. If nothing happens. Click start and type change display language in the start box. A result will then be shown above and click on it. In the window that will appear. There is a drop list. Select language that you want and then click OK
Loida Arcel
Follow the below way:
Start > Control panel > Change display language > Install/uninstall languages > Choose your language from DVD-ROM or Hard disk.
I hope you will be helpful by this.
Notifications
