Antc P180 case is compatible with the PC power
Hello there,
I want to know if the antc P180 case is compatible with the PC power and cooling turbo cool 1kw SR power supply.
Thanks for information.Â
Hello there,
Thank you dear, you know well. Here is some other information that should know:
The power supply is located on the middle on the lower chamber. It is possible to install by screwing but there a bracket too with it which make it tight. So installing process become hard because screw positioning make hassle. You may get a detailed about antc P180 case from http://www.silentpcreview.com/article255-page3.html
Hi Hanley Samson!
Silent Case Style is made advance by the introduction of the Antec Performance p180 cupboard. The ability to offer and processor are separated with the help of two unconnected chambers into separate individual cooling divisions comprising of 5 configurable fans. There are 3 layered-panels which kill the sound in the case.
This is provided so that the stuff stays cool even through the most popular action.
Thanks,"
