Hi.
I want to ask if is there an antivirus for my phone.
I have LG OPTIMUS 3D P920.
I recently using WiFi lately for internet browsing and downloading. I already downloaded a lot of files into my cellphone.
So, I really need to have antivirus because these files are so important to me. So, while my cellphone is not invaded with virus yet.
As they say, prevention is better than cure.
Anti-virus for my LG OPTIMUS PRO C660
Hello Heart,
Howdy? There's a lot of available anti-virus for LG OPTIMUS 3D P920. You really need to download and install one for your cell phone to be able to protect it from all the viruses. You can use AVG anti virus pro. This will help you protect your phone from virus and malware. There's a lot more anti- virus like Kaspersky and dr. web anti virus.
I recommend you to install it as soon as possible so that your computer will be protected and be more secured. Just choose any of those anti-virus I mentioned. Like you said, prevention is always better than cure, so what are you waiting for?
Have a great day!
Zorian
lee hung
75 points
Hello Heart,
For sure there are antiviruses that are used on mobile phones, but you should make sure that when you download them from your PC online, you specify that you are downloading an antivirus to be used on a mobile phone. You also need to specify the kind of phone you are using, for instance it is a Nokia, Alcatel and so forth.
One Mobile phone antivirus that I know is kaspersky, and you can get it for free online. Just Google kaspersky antivirus for mobile phones. Alternatively you can search for the antivirus using your mobile phone on the ovistore or from getjar, download it and then install it on your phone.
Regards
Lee Hung
